Clutch Pedal Very Very Light
Hi All,
Been browsing this forum a long time and need some help with my 07 530i
Driving home yesterday my clutch pedal was catching earlier and it was feeling a lot lighter. It finally got so light that I couldn't get the car into any gear. I ended up towing the car home.
A few weeks ago, I did a brake bleed on the car and based on my reading, the brake and the clutch share the same reservoir. Is it possible that I may have introduced some air into the system? Should I just bleed the clutch?
Any thoughts?
Thanks in advance.
Any thoughts?
Thanks in advance.
Yes they do share the same reservoir. It's indeed possible/likely that the air found its way into the clutch slave cylinder or something. Re-bleed the system. It's either that or you need a new clutch, but sounds like you're not even pushing against the release springs.
It was a bad clutch slave cylinder.
I went to replace it and then noticed that the line connecting the master to the slave was rubbing up against the transmission. I gave it a shot to try to bleed the system and blew out the line (I did check to make sure I installed the slave correctly as I have blown a slave because I installed it incorrectly). I've ordered the line through BMW but they said it would take almost 2 weeks to get here from Germany.
Slightly annoyed this happened at 54000 miles. Oh well.
socale39
09-05-2023 08:30 AM
Faizd
04-27-2015 12:16 PM
