Cluster LCD dimming ?
Old Apr 25, 2017 | 04:42 AM
alexz's Avatar
My Ride: BMW 635D
Default Cluster LCD dimming ?
Hello,
My LCD display is changing too much with the ambient light.
I have found the phototransistor in the cluster :
Any idea what are its characteristics ? I would like to replace it with a resistance, variable eventually...
Thanks in advance !
Old Apr 25, 2017 | 05:52 AM
NoQuarter's Avatar
Engine: N54
What year/model is this? I have not seen any of mine that change dim levels automatically. They are all manually adjusted.
Old Apr 25, 2017 | 08:23 AM
FormerE30Owner's Avatar
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
Mine changes with ambient light. The dash manual control also changes it. 2005 545 MT6.
Old Apr 26, 2017 | 01:13 AM
alexz's Avatar
My Ride: BMW 635D
E60, E61, E63, E64, E81, E87, E90, E91, E92, E93 petrol, diesel, M, ... all have a phototransistor and change with ambient light.
The general brigthness can be adjust manually, but the phototransistor works in parrallel.
newTis.info : Dimming of the instrument cluster.
The brightness of the liquid-crystal display and all indicator and warning lights is adapted to suit ambient lighting conditions. This function is implemented by a phototransistor in the instrument cluster.
The brightness signal is calculated in the instrument cluster on the basis of the following values:
  • Signal from the phototransistor (ambient luminosity)
  • Dimmer signal (on the control panel for the lights)
The brightness signal calculated in this way is made available to the other control units via the K-CAN.
Old Apr 26, 2017 | 05:32 AM
NoQuarter's Avatar
Engine: N54
Wow... I can't believe this is something I have never noticed. I have my original cluster out of the car, now I want to look for the phototransistor
