Cluster dead E60 520d pre lci
My Ride: E60 520d Pre LCI
You keep saying you think it's a module but still haven't checked F41. I'm not understanding your troubleshooting steps. Your issue is with terminal 30g-f. If you want to just check for power check pin 1 on x16759 (51 pin) to see if it's sending out power. If it is then it's not the KGM.
Btw,is it safe to reconnect my 105 ah AGM battery even though the hightest possible entry in the coding is 80ah agm?
