Cluster dead E60 520d pre lci
Old Dec 9, 2024 | 03:23 AM
m47armor's Avatar
My Ride: E60 520d Pre LCI
I coded the new agm battery with ncs expert to 80h agm which was the highest possible one.
today i tested the 18 pin cable which connects to the instrument cluster and there is no power on every single one of the cable. Could it be the micro power module or the kgm?
Old Dec 9, 2024 | 03:27 AM
m47armor's Avatar
Are you the original owner? I can't see that happening by just changing the battery and coding it. Do you mean you coded it with NCSexpert? Are you sure you just coded the CAS and nothing else or made the correct changes to the .man file and coded it back
Originally Posted by donpb
So, all was well up until you replaced the battery? What does the charge histogram show?
You could possibly have a setup issue.
I do not know coding. I usually just pay someone (not the dealer) to code.
I coded it correctly and I only coded the cas. and all was well until I replaced the battery. after I replaced the battery the boot light also stopeed working. No power to instrument cluster. What could it be?
Old Dec 9, 2024 | 07:18 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
It just seems you messed up some where. The key is that the boot light went out so that means something happened during the install. Need to figure out what you fried. If you're not using a towel or something to cover the terminals while installing the battery then more than likely something got touched that shouldn't have. Honestly we can guess all day what it is but since we were not there and can't run tests you're going to have to think logically on how to tack it down. I would start with the boot light and work my way back or check F41 in front fuse holder but if boot light is out I can't see that being the issue. If I was there doing the install I'd know exactly what was touched that shouldn't have been so it would be an easy find
Old Dec 9, 2024 | 03:34 PM
donpb's Avatar
My Ride: '06 530i N52
You simply replaced the battery and now you have all these issues? That all seems very odd and is why I am doubting your diagnostic setup. You could be chasing red herrings.
Old Dec 10, 2024 | 01:39 AM
m47armor's Avatar
I just need to know why my cluster doesnt get any power
Old Dec 10, 2024 | 01:40 AM
m47armor's Avatar
E60 520d M47D2 2005/05 163hp NC31
365.000 kilometers
no power to cluster on the 18 pin cable.
Old Dec 10, 2024 | 02:15 AM
donpb's Avatar
There are many many reasons why your instrument cluster is not turning on. It's not as simple as no power.
We are trying to help you isolate the culprits, but you seem to want to follow your own way.
With BMWs being complex vehicles, fixes are not always simple like with other not so complex cars.
Old Dec 10, 2024 | 03:56 AM
If you need a solid answer an Indy shop would be the place to take it otherwise you're going to have to troubleshoot it yourself by way of us giving you some things to look at. Those are your only choices. No one is going to be able to say "oh it's this", not even a mechanic. You have all the insight of what happened during the install and we can only go by what you have told us.
Old Dec 10, 2024 | 07:32 AM
m47armor's Avatar
Ok so I managed to get the cluster running by connecting 12v to pin 9 and ground to pin 18. The cluster is not dead. My suspicion is the kgm and the mpm module which is integrated in the kgm.
Old Dec 10, 2024 | 07:42 AM
You keep saying you think it's a module but still haven't checked F41. I'm not understanding your troubleshooting steps. Your issue is with terminal 30g-f. If you want to just check for power check pin 1 on x16759 (51 pin) to see if it's sending out power. If it is then it's not the KGM.
