Clunk when braking after moving from start up
Hi E60 members,
I noticed my car has a clunk when I brake immediately after moving from start. This happens either when moving forward or reversing after start up. After this, the car is okay when I brake. My car is an auto. Is it something to do with the brakes?
My Ride: 2008 535i, platinum gray with cream beige dakota leather, premium, sport, comfort access, navigation, heated seats, sport auto with paddles, premium sound, sat radio, ipod
Originally Posted by tosoon' post='796274' date='Feb 18 2009, 09:09 PM
Hi E60 members,
My Ride: 05-530i and 06 530xit
Hi E60 members,
Check your tie-rods-my car was making the same sound and i jack it up and it was the tie rod ends--about 100 bucks from the dealer and 60 bucks outside of the dealer
My car is a 2005 E60 model. Read that a tie-rod is part of the steering system. I'm not turning the steering wheel when I move the car. The clunk only happens when I start up the car, move and brake. Afterwards, it is fine.
By the way, not sure if this is related, does it make sense for the steering to wobble a little when the engine is cold when travelling on the highway. When the engine is warmed up, he wobble seems to disappear. Strange?
My Ride: 525
Sounds very much like brake pad chatter. It's caused when there is a slight space between your pads and rotor. The first time you hit your brakes on start up, the pressure closes this small gap and it sometimes causes a slight clunk sound.
How much life to you have left on your pads? If they are very old, go ahead and replace them and that will likely fix the noise.
There there is still decent life on the pads and you don't want to replace, try cleaning up the calipers and possibly purchasing a spacer to place behind the pad. This will allow the pad to slide more smoothly and prevend a clunk.
In any event, have someone pull the wheen and do a quick inspection. It doens't sound like a major deal, but a quick inspection will help restore confidence in the brake system.
My car is a 2004 e60 530i auto
I had the same symptoms.
A clunk heard when braking after changing direction forwards or backwards. The clunk was heard only once, until the next change of direction.
The front brake pads were replaced - problem solved - cost ?100 at an independent
My Ride: 2007 BMW 550i Alpine White, Black inside,Sport Package, M Tech kit, SMG, Navigation, Cold weather package
[quote name='mk0155' date='Dec 29 2009, 10:51 AM' post='1081183']
I had same problem on my previous 745i now same think on my 550i I new it's something with brakes.
My Ride: 2006 525XI, Jet black on Dakota beige. Premium and winter packages. I consider myself a purist and intend to keep my car absolutely stock and shiny.
2008 328I Convertible, Sapphire black on beige interior. Premium package, NAV, iPod adapter.
Retired: 2002 325I, Titanium silver on black leather. Premium package. Absolutely stock and proud of it.
Could this be just a cold weather related thing? Does it do it when the temperature is above freezing?
Hi.
This happens to me too, all year, and my guess is that the front brake caliper moves slightly upon the first braking, since the brake cylinders might retract more than usual when car is left unused over night, causing the calipers glide bolts to be somewhat "more stuck".
I have a 525d 2005 btw.
Tommy.
Tommy.
