Climate control
My Ride: E60 545i stock
When you change the pump and thermo it should be good. Just make sure you bleed the system after the change. If you're doing it yourself look at YouTube to find a how to on the bleeding procedure. Ensure you car is hooked up to a battery or the battery is fully charged.
all three replced
Heater xchange valve
Water pump
Themo
I now have heat its not to bad fiddle with the heating knobs it cools but its giving me heat. The system as i know sdlf bleads leaving the cap off so apart from relacing heating controls what else is there to do
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Couldn't really understand what you were saying. Are you saying you changed those parts and afterwards you did a self bleed or did you let the car do the bleed by triggering it?
After you did the bleed you're only getting heat and no a/c. If so redo the bleed procedure and make sure your exchange is hooked up correctly and working.
