Climate Comfort Laminated Glass option (356)
My Ride: 2006 535d MSport ; Retired at 110,000 miles
October 2010: 2010 535d MSport; Space Grey/Black Dakota, Adaptive Xenons, High Beam assistant, Prof. Nav, Voice Control,SAT, Adaptive Drive, Powered boot, Comfort Access, Climate Comfort W/Screen, Surround View, Side/Rear Sunblinds, Comfort Seats, HUD, Active Cruise, TV, Prof Loudspeaker, Night Vision, Lane Change warning, 4-Zone A/C, split rear seats, Speed Limit Display
I had a Climate comfort windscreen on my last car - E39 M5 - and it wasn't very effective.
On the E60, its applied to all of the windows, and it really does make a difference, car cools quicker, and when the sun is on the windows you don't feel like you are in a greenhouse, the glass takes most of the heat from the sunlight. I'm glad I had it fitted.
One problem it causes though...my car has a satellite based anti-theft system ( NOT Tracker ), and I also have an origin B2...both have GPS antenna which need to be placed so that they can get a signal.
CC Glass seems to be very effective at screening GPS sugnals, so the fitter took a couple of hours before he could find somehwere to fit the antenna where they couldn't be seen but were not blocked by the glass.
PelicanParts.com
07-24-2015 01:26 PM
