CIP 16.2 finally installed
Old May 14, 2005 | 08:55 AM
ricky's Avatar
My Ride: 530e G30
Model Year: 2017
Today I had back my car updated to 16.2 .
After few km I noticed something wrong:
Nav thought to be at Munich, ok I thought the mother's voice is aloud.
BT phone showed to me perfectly functioning no way to pair it.
Bad start resolved in about 30 minutes:
Nav finally understood to be in Turin, may be it was difficult to it to accept to be in Turin where are located FIAT headquarters .
For BT phone it has been sufficient to repeat pairing process.
Radio station and seat memory to be reprogrammed.
Finally all OK.
I noticed some changes/enhancements:
3D visual added on Nav, very nice, useful lateral commands, specially cursor allowing you to navigate around Europe (in my case) with resolution from 100 mt to 1000 km.
In 3D visual (resolution 100-200mt ) you loose streets name, but you continue to have names in 2D.
Voice command: before you were invited to talk by a beep, now a voice girl invite you to talk.
Finally level volume of audio source is "memorized" and when you switch ignition on again you have same volume you had when you switched off.
Having Radio pro and Nav pro MP3 aren't working but I knew, Iceman was very clear.
Dipped headlight, not in auto position too, are automatically switched off when you switch off motor.
Steptronic seems to be more aggressive (specially in DS), but it may be only a personal impression.
I attended to a part of the updating:
when system test and set up dinamic drive it is very impressive for the sudden and hard inclination of the car and for the long excursion .
Tsoup
15
Dec 20, 2021 11:14 AM
Nihilation
May 30, 2015 10:35 AM
dvw
28
May 12, 2004 08:39 AM
jonboy
Apr 14, 2004 04:48 PM
cidair
16
Mar 23, 2004 07:55 AM
