Cigarette Lighter Power Wiring
#21
Originally Posted by bob.a' post='439062' date='Jun 23 2007, 06:57 PM
The main point is that it was a comment attributing responsibility for the mess to BMW; not to the dealer.
Of course if BMWUK say it's the dealer's responsibility to read, query and understand the Product Launch Support Literature... (let's hope they don't)...
ABC
#22
My Ride: LCI E60 520d SE Manual, Jet Black/Natural Brown/Light Poplar, Auto A/C, Elec Front Seats+Lumbar & Driver Memory, SCA Doors, Thru Load, Auto Dim Folding Mirrors, Adaptive Xenons+High-beam Assist, LDWS, USB Audio, 244 wheels+RFTs (until worn) & S-S Spare
Originally Posted by aybeesea' post='439103' date='Jun 23 2007, 08:42 PM
So to finally understand, you're pursuing a "warrantable solution" because of BMWUK's failure to train the dealer.
ABC
ABC
#23
Originally Posted by bob.a' post='439121' date='Jun 23 2007, 09:37 PM
My guess is that there was no such information at that stage, so it is BMW's mess..
ABC
#24
Originally Posted by bob.a' post='439041' date='Jun 23 2007, 06:05 PM
Which fuse protects the front ashtray 12V socket on cars that have it installed? My car has 20A fuses plugged in both #87 and #88, but all three of the installed sockets (2 in the rear and 1 in the boot/trunk) are connected to #88.
Also, can anyone tell me the colour of the harness wire associated with fuse 87?
Fuse 87 - Front socket and passenger footwell socket (US)
Fuse 88 - Both Rear sockets and boot socket.
You could tap into Fuse 88 via pins on a connector on the fuse box.
For the Fuse 87 to need to also tap into a connector X11012 on the rear fuse box over the battery. This is a large 32 pin connector and you will need to use pin 25 for the front socket (Green/White wire) and pin 24 for the passenger footwell socket (Green/Black wire). My biggest fear is that the wiring loom may not be present so it will require a very long wire from the front of the car all the way to the back fuse box.
I have WDS10 which doesnt seem to have the LCI cars on it. So all this information is for Pre-LCI car built after 2006-09
#25
My Ride: 520d SE
Jet black / anthracite
Advanced air con
Sun protection glass
USB
Style 244 wheels
Originally Posted by Bart sMartWeed' post='439019' date='Jun 23 2007, 03:55 PM
I had exactly the same problem with my LCI 525d. I asked the tech people in the dealership to give me a solution and the proposal was to build an extra 12V outlet in somewhere but that would take about 3 hours of work because of the additional wires they had to put in. :thumbsdown:
In the opinion that it couldn't be possible BMW doesn't provide some kind of 12V outlet I read the manual again and ... there is one at the passenger side after the glove compartment. You have to know it is there else you won't see it. The dealer didn't know it either, I had to tell them!
So, no worries, there is one.![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
Could I just check, do you have a UK spec car? There seems to be differences between UK and specs for other countries.
#26
My Ride: 520d SE
Advanced air con
USB
Style 244 wheels
Originally Posted by bob.a' post='439024' date='Jun 23 2007, 04:49 PM
I'm not quite clear what implications you were told about. UK pre-LCI "non-smoker's" cars did retain the 12V socket and I've not heard of any limitations different from those of "smoker's" cars - obviously, both are compatible with the Garmin GPS units BMW UK dealers sell. My rep knew the over-view of the console re-design, but evidently had not been warned that the effect of deleting the smoker's pack on an LCI car would be different from that he was used to on pre-LCI 5's and other models. So, he told me the socket would be fitted.
Bob.a
I had a look in the price list booklet for the LCI 5 series, the one that sets out the option prices and detailed specs. This states that the power sockets are retained when the smokers package is deleted, although it is not clear which power sockets they mean. It certainly has no warning that the front power outlet is deleted...
Have you checked under or around the glove box? Bruce Miranda says that he has a power socket under there somewhere, but not sure if his car is UK spec.
I may try to amend my order to put the smokers pack back in, but I suspect it may be too late...
#27
Originally Posted by Lord Monkey' post='439424' date='Jun 25 2007, 09:07 AM
Have you checked under or around the glove box? Bruce Miranda says that he has a power socket under there somewhere, but not sure if his car is UK spec. ![Confused](https://5series.net/forums/images/smilies/confused.gif)
As for the issue with the LCI cars I understand that both the front socket and the passenger footwell socket are missing. So if you want to make an official retrofit you will need to pull a wire all the back to the fuse box over the battery.
The easiest thing in my opinion is to simply extend the rear sockets to the front socket. That way you only need a small bit of wire running inside of the armrest.
#28
Bob.a
1) That price list was superceded by a new version (the current version) in which the Option (441) Descripion column reads "Can be deleted, which replaces the ashtrays with oddment trays. The 12V socket in the front is also deleted." I don't know when this version was distributed, but it is dated March 2007 - the same as the version you looked at.
2) Yes, there's definitely no front passenger footwell socket. My guess is the absence has something to do with the RHD design conversion. (There's also no socket on the Driver's side, though I suppose that might be considered unsafe.)
3) In your position I would attempt to get the change made, if only to lay a clear marker as to what your expectation was when you placed the order. It's a tricky problem to deal with once you've taken delivery.
#29
Hi,
can you show some pictures of where is the exact place? Thanks.
#30
Originally Posted by tume' post='439442' date='Jun 25 2007, 12:15 PM
Hi,
