cig lighters not working?
My Ride: 2008 535xi
V1 hardwire
Laser Interceptor
12" JL Audio Ported PowerWedge enclosure with one W1v2
20% tint
The cig lighter under my glovebox and the one in the ashtray by the shifter both do not work. I checked all fuses, and they are fine. i verified that both sockets were dead with my cell charger cord and then with a multi meter.
Any ideas what could be wrong? Do these have to be "coded" on for some reason? The ones in the back seat work just fine.
Thanks
Thanks
My Ride: 2008 535xi
V1 hardwire
Laser Interceptor
20% tint
They visually looked fine, but I did not check for continuity across each.
Do you know which fuse the cig lighters are on? The little diagram in the trunk wasn't much help, so I had to pull and check (visually) each one and I'd rather not do it again.
Thanks
Thanks
I was told by my indy mechanic that the fuse for the lighters (10 Amp) is not enough for the charging of cell phones, iPods, etc. He swapped it out for a 30 Amp fuse and I've been fine ever since. Even if it looks okay, if you can swap it for a 30 amp fuse.
My Ride: 545i Sport
Engine: N62
My Ride: 2008 535xi
V1 hardwire
Laser Interceptor
20% tint
not on my car; my diagram is a bunch of pictograms that are impossible to decipher.
is that diagram from an 08 535? my trunk fuse arrangement is way different than what is shown above.
My Ride: 545i Sport
Engine: N62
