Check engine light " Increase Emission " - Help !!
Old Oct 3, 2008 | 11:08 AM
sean_954's Avatar
My Ride: 05 , 545i .........stock for now !!
Question
Ok .....i went in my car lastnite to go the club and i got this message that came up with the check engine light ......can someone explain what may be causing this ......pleasee !!!!
Granted the car only has 45k miles on it , by the way its a 05 - 545i sport .
Old Oct 3, 2008 | 11:13 AM
gotabyte's Avatar
My Ride: 2008 550I M Sport, Premium pkg, Logic 7, Sport Automatic Trans, Paddle Shifters, Nav, Comfort Access, Rear Shades, Satellite, PDC
Make sure your gas cap is on tight. This is the most common reason. After that, the computer will have to be scanned to see what is failing.
Old Oct 3, 2008 | 11:17 AM
sean_954's Avatar
Thumbs up
Thats on tight ...just went to check , would my sprint booster be a problem but then again i had it on for about 3 months now with no prob .
Old Oct 3, 2008 | 11:18 AM
Ricracing's Avatar
Sensor failure, is my guess.
But if you have filled up with wrong gas the cat is gone.
Could be a injection failure (or sensor) problem as well.
Old Oct 3, 2008 | 11:20 AM
sean_954's Avatar
I only use 93 octane at the pump ......hmmmmm but u got a point about the sensor , since it say " emissions " hmmmm ...
Old Oct 3, 2008 | 11:32 AM
miguex's Avatar
From: Calgary, AB - Canada / Buenos Aires - Argentina
My Ride: 2006 BMW M5
I think he means Oxygen Sensors... you have to run the ODB2 diag to see the code number of the issue or go your dealer.....
Old Oct 3, 2008 | 11:43 AM
sean_954's Avatar
ohh ok .....i shalll make an apt. to take the car in tomm. morning .......thanks again guys !!!!!
Old Oct 3, 2008 | 12:10 PM
BMWRINO's Avatar
Read this thread from last month for some details: http://forums.e60.net/index.php?showtopic=61030&hl=
Good luck!
Old Oct 3, 2008 | 12:42 PM
billeul's Avatar
Same thing happened with car 3 weeks ago. As long as the car is still running OK, You should wait a week or so before you do anything.
My light reset within a week and has not come back. I assumed it was probably a misfire or glitch.
If you don't want to wait, take it somewhere that will scan the ODB2 codes for free to see what code was set and preform a reset. I can do it myself, but I've heard Autozone's do it for free. If the code comes back, then a trip to the dealer might be warranted. Taking it to the dealer tomorrow might be a waste of money, unless you are still under warranty. BMW electronics are very glitchy and quite often set false codes. Good luck.
Bill
Old Oct 3, 2008 | 02:32 PM
sy1616's Avatar
Same thing happened to me last week, cars in the shop for it as we speak....05 545i sport oddly enough i drove it for a week afterwards and all was fine!
