5Series.net - Forums
-   -   Check engine light fixed itself? (https://5series.net/forums/e60-discussion-2/check-engine-light-fixed-itself-115773/)
Shydee Aug 1, 2011 07:11 AM
I own a 09 535i and recently got a check engine light with engine malf reduce power.
I stopped the car and restarted it which did the trick and went away.
To make sure everythin was alright took it to a dealer and have them check it out.
They told me that they dont see any code of it and it might of fixed itself.
Is that even possible??
porando Aug 1, 2011 07:49 AM
yeah i.e if you leave gas cap not tightly screwed it will fire CE but once you fix it - it will go away....
Shydee Aug 1, 2011 07:55 AM
Good to know! Thx for the info!
donpb Aug 1, 2011 10:16 AM
yes my mechanic told me that the bmw can fix things.
luigi524td Aug 1, 2011 10:20 AM
+1 So will a loose / improperly tightened oil filler cap ...
Steveo Aug 6, 2011 06:56 AM
Get JB4 and check yourself. Enjoy the improved performance, and self diagnosis.
