check engine light on 535i 2008
Old 03-16-2014, 02:29 PM
08535xiNJ's Avatar
I was having the same issue and it ended up being carbon buildup. Had the dealer walnut blast the intake and problem went away. Had around 60k on my car when this happened.
Brian
Old 03-16-2014, 03:38 PM
anthony_ms's Avatar
My Ride: 08 e60 535i
I went to stage 2+ fmic today and had a misfire in 4.. not sure what it is yet but getting shuddering when going wot then to limp :/ ... will figure it out tomorrow for sure
Old 03-16-2014, 06:18 PM
Booyaazaa's Avatar
Check your coil by swapping it with another cyl since another post said you did plugs 10k ago.
Originally Posted by pavrom
unfortunately i am not that lucky … today i got misfire on cylinder 5 … almost same symptoms
Do the same to make sure it's the coil since you just replaced the plugs. If you still have a misfire on 5 make sure the plug is gapped correctly and torqued down properly. Unless the plug is covered in fuel then it is probably carbon build up.
Old 03-16-2014, 07:31 PM
anthony_ms's Avatar
[QUOTE=Booyaazaa;1534138]Check your coil by swapping it with another cyl since another post said you did coils 10k ago.
Did the plugs but not coils.. ill def try this tomorrow
Old 03-17-2014, 11:59 AM
otisdawhino's Avatar
My Ride: 2008 BMW E60 535i
Sounds like carbon buildup to me. Right mileage for it and symptoms. Time for a Walnut Blasting !!! Good luck :-)
Old 03-17-2014, 12:56 PM
mtylerrose's Avatar
My Ride: 2008 535i
Same thing happened to me recently. Problem was the injectors. Those were replaced under warranty, all is well.
Skavilla
04-21-2015 03:43 AM
Stranger12
04-05-2015 10:42 AM
Sic Sticks
03-30-2015 01:17 PM
jl21
03-29-2015 09:53 PM
laz1left
03-11-2015 11:15 AM
Quick Reply: check engine light on 535i 2008
