check engine light on 535i 2008
My Ride: 535i
i recently noticed when i put car in sport mode and floor it i feel car bit shaking .. to me it seems like not enough fuel getting where it should be … similar symptom of injector problem on the diesel semi truck engine , check engine light goes on and when i stop at the stoplight right after car still shakes little bit.
i pulled over on the parking , turned engine off , started - no check engine light , i tried to floor it again (was not sure if something wrong with shifter programming , recently did SAT retrofit) - same situation , but after starting the car again check engine light is still on , today i tried to push little bit gas pedal at 30-40mph in regular D - shaking
stopped at auto zone just to check the code : p0303 (not sure if this is bmw code from auto zone keychain scanner
cylinder 3 misfire :
causes
a. plugged of faulty fuel injector
b. vacuum leak
c. engine mechanical condition
i am at 59xxx miles , any ideas ?
mechanic said he used to have 335i with same problem , that time it was injector , he used 3 times techron injector cleaner and the problem was gone … not sure where to start.
thanks
causes
b. vacuum leak
thanks
Did you replace the plugs at the regular service interval of 45-50k? If you did then swap coils to make sure it's not the coil. If the misfire stays on cyl 3 then that injector is bad and that bank will need to be replaced. Definitely not a vacuum line issue. Gut tells me its a injector.
My Ride: 2008 535i Fully loaded
I have had the same problem, first i changed the spark plugs to different cylinders, if the code appeared on a different cylinder, then the spark plugs are bad. Then again you can hear if the injectors are bad.
Don't buy a coil until you confirm its bad. I had same problem and it was only a plug. While I was in there I swapped the coil with anothr one and if the coil was bad the problem would have moved. It didn't so plugs were the culprit.
My Ride: 535i
replaced plugs today and coil number 3 - fixed the issue
i was pissed of the fact that i need 14mm 12 point socket to get plugs out … not even regular one but thin walled or 14mm 12 point spark plug key , i spent 1 hour today finding this key , not in any auto store , not in sears … later on my friend mechanic brought it for me to do the job , before i changed the plugs i put new coil on cylinder 3 and this fixed the issue right away , since everything was ready for the plugs - i did this too.
thanks again guys
thanks again guys
thanks again guys
thanks again guys
