Check Engine Light
My Ride: 2008 550i M-Sport
I have had a check engine light for about a week. I went to a auto parts store to have it read and the reader did not give a description. P013C Any help is appreciated. I have already replaced on O2 sensor and I figure it is one of the other three.
Roger
Roger
P0130 is MAF sensor, I believe, you can try cleaning the sensor and see what happens.
Looks like it might be another O2 sensor:
http://www.aboutautomobile.com/DTC/P013C
HTH,
Jim / crewer
HTH,
Jim / crewer
According to Bavarian Autosport, your N62 V8's bank 2 is cylinders 5 - 8 on the left (U.S. driver's) side. The Bentley manual (page 120-2) shows cylinders 1-4 on the right side, and 5-8 on the left side, so the left bank looks like bank #2 to me.
Yeah, sensor 2 sounds like the one after the cat.
HTH, and best of luck!
Jim / crewzer
Jim / crewzer
Ok it is something more serious. Today the light came on and it was flashing and the car was misfiring, badly. I must have bad fuel, bad coil, bad spark plug or ??? I turned the car off counted to 10 and started it again. Now no light or issues. Appointment made for Monday next week.
My Ride: See signature
best1, I just had that happen to me with the scary and dreaded "engine malfunction" message but turning the car off then back on did not help. I had to have the coil for cylinder one replaced and they also replaced all of the spark plugs.
