Charging Battery
My Ride: Sapphire Black 07 530i non-sport
7000k Angel Eyes
6000k HID Xenon adaptive turn Head lamps and Fogs, Clear LED Turn Signals front/back and side markers. Clear bright license plate lamp. Full interior lighting upgrade.
Coding: daytime angel eyes, auto windows up, and digital speedometer. (Thanks to John at Motorcepts.com)
OEM Tinted LCI Tail lights (Thanks to David at http://www.luxmotorwerks.com
Oem Mtec rear bumper with diffuser and M5trunk finisher
Debadged! The best paint work! (Thanks to Desimone BMW)
20x8.5 +18 20x10 +25 Concept One RS-8 Black Machined Chrome Lip
V6.1 cables (Thanks to Bruce Miranda)
Nitto Invo tires 285x30 R20 - 245x35 R20
Discounttire.com
Vac Motorsports ecu chip upgrade, and fender roll
http://vacmotorsports.com/
wish list:
Rieger Front bumper
Hamann side skirts
Custom quad exhaust
Rpi Ram air intake scoop
M5 SMG shift knob
KW Variant 3 suspension
Brembo Big Brake kit
LCI Heads
Tints
BMW M5
Charging Battery
I just purchased a Noco Genius Battery charger for my 2007 E60 because I'm getting a battery alert and code U112B from the OBD reading.
(Lost Instrument Pack Status)
I've never done this before, so I thought it would be wise to ask someone here if its absolutely necessary to disconnect the positive and negative before charging.
Also I heard that I only need to connect the positive and put the negative somewhere else?
On the Noco charger there is a 12v hot / cold and 24 hot / cold charging setting on this charger.
Should the battery be charged at 12V?
HELP
HELP
You need to connect this to the positive and negative connection points under the hood and not to the battery itself. You can find these points in the owners manual under jump starting. This is 12V only. Do not use 24V.
