changing off fan motor
My Ride: Bmw 520i E60.
Black with black leather , new lci headlights , M-Tech bumpers and M-Tech Side Skirts, M5 mirrows, 8,5 and 9,5 x 19` Org M6 wheels , Led rear lights, M-Tech steering wheel, M5 short shift, M5 foot rest, 2x2x90mm supersport exhaust, 50mm lower springs, shadowline, xenon 6000k, Led licens plate light, AC Schnitzer rear-lid spoiler.
Hallo All.
Does anyone have som pics showing how to change a fan motor ??
Thanks guys ..
Kim Denmark ..
Thanks guys ..
Kim Denmark ..
My Ride: 545i sport
Might help if you tell us which fan motor. I will assume the one under the hood (engine cooling). No pics, but it is simple:
1. Remove top core support cover (metal piece over radiator). Unscrew hood/bonet latches first and then set aside.
2. Remove plastic radiator/condensor cover (5 screws).
3. Disconnect AIC wiring connector and set aside.
4. Disconnect fan wiring connector and set aside.
5. Lift fan assembly straight up slighty and then fold back (toward engine) the left side fan assembly support tab. Continue to remove fan.
Done.
Done.
Sorry , the fan i mean is the one inside the car , hot and cold fan ..
My Ride: Bmw 530d 2004
Maybe this online TIS guide helps you out:
http://tis.spaghetticoder.org/s/view.pl?1/08/86/96
Please note that there are few other preliminayr tasks that you have to do before getting into this point. I think you can find the instructions for those actions also on TIS.
- Antti -
- Antti -
UltimatePeter
DIY: Do It Yourself
05-12-2015 08:00 AM
thesalboy
04-08-2015 09:13 AM
