Changing Angel Eye Bulb - Pre LCI Xenon
My Ride: Coming soon...
Can anyone point me to a DIY for changing the angel eye bulbs on a pre-lci E60 with Adaptive Xenons? The manual says to take it to the dealer but no way!! It seems they make this recommendation because of the high voltage running to the xenons, but I should just be able to unplug the battery right? I've seen a video online of some asian dude changing the bulb, but it looked like he was working on an LCI car...
Look in the DIY section and search for John's thread on Mtec angel eyes. You do not have to disconnect the battery. Just remove the current one and screw the after market one in if you have the plug and play kind. I found it's much easier to remove the headlight but some were able to do it with a long neck plier.
did you try searching for it? there are a few discussions regarding this...
here's the easiest way (just need needle nose pliers): https://5series.net/forums/topic/368...ge__hl__needle
or you can search for a few other threads regarding removing the headlight to get to the bulb...
just did it...i think you're right Simon, Orion will be next for sure.
The 5watt is slightly brighter than the Mtec 2.1 when dark but not very noticeable and about the same outdoor.
BTW, I switched out to Mtec 2.1 awhile back and forgot what a pain it is to insert the bulb and tighten it. Not enough room to put my hand in to have good grip.
Also, anyone know the easiest way to clean the dust inside the lens cover or I should just leave it like that until I pull the trigger on the Orion?
![Fcuk](https://5series.net/forums/images/smilies/imported/fcuk.gif)
My Ride: '06 M5 Silver/Grey BLK, HUD, SMG, fully Loaded...RPI Scoops Red, Block Off Plates, BMC Filters. Hyper Silver Painted Wheels, RPI Full GTS Exhaust
Hi All, I was looking to purchase the Mtec 3.0 for my 06 M5, anyone had experience with these? I hear they are brighter, and have the proper cooling than any others on the market - any info would be appreciated.
My Ride: BMW E60
Model Year: 2016
The alternative, of course, is to divide each ring to have the ring receive its own light source, making it 4 bulbs total. But ultimately, it would still require cutting open the headlights to achieve this anyway.
As for cleaning the dust inside... it's a toughie man. Go to craft store and pick up some pipe cleaners. You can wiggle it through from the back opening and basically "do your best".
![Dance](https://5series.net/forums/images/smilies/imported/dance.gif)
Thanks I got the v3's for $189 shipped so not that expensive.
Ouch! I got mine about 2-3 yrs ago off ebay for $30.
In fact I sold my OEM bulbs for double what I paid for the new ones. I don't know, Maybe you guys think that's not expensive but that's very expensive. What do you think the actual overall cost of production is? Pretty low per unit. But just multiply that by ignorance (no offense) and the automotive world's "advertisement campaign's" and you think you got a good deal. For example look at the pharmaceutical companies. Do you think the cost of production (overall cost) is so high? No, they're raking your money in and giving you other diseases while they're at it.
In 2004 I bought some aftermarket HID's for the E46 (i think DS2?) for like $35 a pair 6000K because the stock ones (i think 4300K , don't remember) didn't see bright enough. Here we are almost 8 yrs later and not a single problem! Do you think I'd pay $150 for an inferior bulb just because they have a name or because BMW recommends them?
