CENTRAL ELECTRONIC FAILURE
Old Mar 6, 2009 | 10:00 PM
guldbil's Avatar
My 2005 530D shows: Central electronic failure, and all the lights inside car is flickering, The nav screen shuts off, the rpm and odm goes crazy up and down, all lights EDC, ABS,AIRBAGS,ENGINE and so on turns on, the wipers start, the only thing running "normal" is the engine and headlights.
Anyone that know what this is ??? I will go to the dealer monday, byt have anyone tried this ??
Old Mar 7, 2009 | 08:33 AM
Ricracing's Avatar
You don't tell us what MY your car is?
It could be that you need a new battery if your car is a '05 or older.
Old Mar 7, 2009 | 09:49 AM
BenAnd's Avatar
My Ride: BMW e60 525IA 12/2003
Hi
Have you being mounting some ekstra modes ??? , if its not a battery faliur , i could sound like the K-Can Bus , or the PT-Can Bus has been "fucked" up durring a retrofit of some ekstras in the car.
Old May 10, 2009 | 03:06 AM
Nosferatu's Avatar
What did cause this?
Old May 10, 2009 | 04:04 AM
luigi524td's Avatar
If you're 'lucky' it will be a battery failure - if your battery is the original it may have given it's last volt.
Our e60 suck the life out of batteries like some Washington legislators suck money out of taxpayers wallets.
Old Mar 17, 2010 | 09:08 PM
chin moo's Avatar
My Ride: 2004 525ia, Olivin green, active steering, sunroof, bi-xenons, power assist, bluetooth phone system, Professional stereo with navigation, sprint booster, Goodyear F1 235/40x18 for in town drives, 16's for country roads
Old Mar 17, 2010 | 09:17 PM
chin moo's Avatar
My 2004 525i went into dealer with same problem. Started with battery drain, then after charging each time more warning lights came on, then lost i drive screen. Dealer after 2 weeks has narrowed it down to a KGM module about US$750. I hope that may be all. Initially a mechanic suggested changing the i driveUS$2600!I told the service manager to get real and have them do a proper analysis first.
Old Mar 17, 2010 | 09:49 PM
safetywork's Avatar
My Ride: 2008 550i Sport (6-speed)
Check the area in and around your spare tire, is it wet? There's a module that controls many of the electronics located in the spare tire well. If the drain is plugged in your sunroof, water could get into the trunk and collect in the spare wheel well. Also check the batter tray for water. If it is wet, that module probably toast.
LandRange
Oct 5, 2015 08:47 AM
Henry Peters
Sep 25, 2015 10:15 AM
Claudiupromotion
Sep 17, 2015 08:02 PM
Gadamsm5
E60 M5 Discussion
Sep 15, 2015 11:43 AM
LandRange
Sep 6, 2015 10:39 AM
