So I bought a cd changer from a member. Installed it, loaded it up and it loads and scans through each tray. But its not selectable in Idrive. Says, "No selectable or supported audio media in either internal drive." Each cd I have tested in the cd drive previously with no problems. I have tried it with and without cd's in the dash cd and dvd drives. I have the option list sheet for my car, though it was purchased used. It and a vin check both say it is pre-wired for a cd changer and sirius radio. So after trying every way I could think of to make this work, I dismounted it and unplugged. This is when I noticed the plug itself. It only has two wires from the car connected to it (see photo). The plug looks like it has forms for something similar to RCA connectors but with no wiring. My question is, is this correct? or is it missing something?
Thank you for any help! http://i1174.photobucket.com/albums/...-23-17_686.jpg |
Pre-wired but needs to be coded. You'll need a dealer or indy with the correct coding equipment.
hmmmm, I was told it was plug and play.
Anyway I was wondering about only two wires. I guess I'm thinking they would have to be power and ground so how does it get audio? |
They are fibre optics for the MOST.
You need to do a little reconfiguring before it will work depending in your set up. You should see a red light on one of the lines to that plug |
Yea i think it just needs coding.. :) Just like I installed my aux it needed to be coded..
Originally Posted by CHR15
(Post 1471022)
The MOST buss lines are usually taped somewhere near. You may have to remove the bottom passenger side access panel to get to it. It will be a stiff green plastic fibre optic wire, with a black connector in the middle. That is the buss wire. You will need to unclip from the black connector (leaving you 2 end points). One side will light up. You will need to pick up the end connectors from your dealer. Once the end connectors are on, push the lighted side into the #1 connector on the plug you discovered and referred to as a possible RCA connectors. They are actually where the fiber lines attach to the changer. One side is fibre in. The other side is the output. Once completed, you will need to code the car to recognize the changer. I had the same 'fun' when I added my changer.
Originally Posted by advancedlogic
(Post 1471081)
On your picture the MOST Bus is not visible.
Have you found it yet? Also as people mentioned above, it will definately need coding. |
Originally Posted by delwarulislam
(Post 1471116)
Have you found it yet? Also as people mentioned above, it will definately need coding. Thank you all for you help and insight! |
| All times are GMT -8. The time now is 11:51 PM. |
