CCC unit
Hi all
Not sure if this has been done before , ive had my ccc unit display flash on and off purchased an 2006-2007 5 series ccc unit but the front panel was different so swapped over from, old unit and installed the unit , my bm is a 2004 model , the display dosent streak or flicker but now comes up bmw for a few seconds trys to read a disc and flicks off then 10 seconds later the same is there a possability the head unit i swapped over is the issue if so i will modify the front bezel or is there another issue im overlooking here . Ive had 3 evos before this and was straight forward compared to this .
I swapped the original face that come with the new one back fired up the system and it started and worked perfectly
kd7iwp (12-05-2021)
kcmckinn17
01-15-2021 03:51 PM
