Castrol vs BMW
Old 08-23-2010, 07:35 AM
bmwdinan5's Avatar
Ok so my question is the Castrol Euro Blend the same thing as BMW's OEM oil? Just rebranded BMW?
If not, is the BMW brand a Full Synthetic?
Old 08-23-2010, 07:46 AM
545felix's Avatar
My Ride: 05 545/6
Originally Posted by rctmthouse
Why not go with BMW oil since it costs the same, at least for where I am.
my dealer wants $300 for a frickin' oil change. I'll do it myself for $90 in parts, thanks. just put in the 0w-40 Mobil1 on the approved list. technically I can get the BMW oil for about $1 less per quart at the dealer, but I wanted to try the Mobil1 and I like the extra range on the top since temperatures down here tend to run a little high.
Old 08-23-2010, 08:54 AM
salaki's Avatar
My Ride: 05 545i 6MT
15K miles oil change on Idrive isn't real miles driven.
Idrive count drops faster depending on how you drive (traffic, short distance, etc)
If you drive from Alaska to Miami then back then back again for full 15K miles, then I'm sure the Idrive will will match/be close to the actually mileage driven.
In my case 15K Idrive = 9K miles real driving.
I use German Castrol and change every 8500 real driving miles regardless of Idrive.
Old 08-23-2010, 10:55 AM
CVTBenhogan's Avatar
My Ride: 2006 BMW 550i "Ben Hogan's 5 Iron" SilverGrey/Black Sport, L7, NAV, CW, AS, Split FR 2003 Audi A4 3.0 CVT "Part of the Moniker" Silver/Ebony, Prem, CW, Star 17s
Originally Posted by bmwdinan5
In every forum this is always dicussed, but was at Pepboys and say Castrol's Euro Formula. About to do my first DIY oil chain on a 550i. Should I go with BMW oil or Castrol Euro Formula? Is the BMW oil the same stuff?
Thank you
Completed my DIY oil change and used Castrol Euro Forumula 0-30W. As others mentioned, 0-30 for Castrol is the correct number. Would have gone with Mobil 1 but the Castrol was cheaper by $1 per quart. I suspect the BMW oil was made by Castrol.
BTW. The DIY was a snap with ramps. One thing. For the drain plug, make sure you hold on to it, as the oil drains fast. I've never seen oil drain (it gushes) so fast and the plug flew into the oil tray and slighly blocked its draining. It was like watching a toilet bowel almost spill over. Almost. Make sure to buy a 24MM socket for the filter housing too, its plastic and will easily strip if you use a wrench. Also, I'd warm up the engine when cold only for a bit. There is alot oil in the engine and it stay hots for awhile. Used a nice Mann filter and I liked insert type filter.
Overall, the 5er is tidy as heck down below and a pleasure to work on. Nice machine. Another oil I'd consider is Valvoline synthetic, a oil comparo had it performing better than Mobile 1. Overall, I'm not too concerned on the oil brand, as the change internvals will be 5K or before Winter/Spring.
Engine running smooth as glass. Next change December.
TroyE60
05-30-2019 05:01 PM
mortyk
03-31-2015 04:49 PM
JonathonK
03-27-2015 08:13 AM
trev0006
E34/E28/E12 Discussion
03-20-2015 11:19 AM
reckamech
09-08-2003 01:24 PM
Quick Reply: Castrol vs BMW
