car wont start ! help !
My Ride: 2004 525i Executive
2004 525i
when i turn the key, nothing happens, not even the solenoid clicking
all electronics works as normal, means cant be battery...
My Ride: 540i
Model Year: 2017
If your clutch/brake safety switch has failed you should get an indication on your display at start up.
If I understand the Battery Safety Terminal, it can disconnect the starter/alternator, and still leave power to the electronics. (usually in the event of an accident) http://www.rfdm.com/tis/12_42_540.pdf
Failing batteries seems to be epidemic. Maybe the battery voltage is too low to engage the starter. Will it jump start?
GL and don't get frustrated!
maybe i didnt jump start it correctly? i connected the positive to the positive terminal on the engine bay and the negative to that "special nut" near it
My Ride: See my signature
Originally Posted by borisnewn' post='987930' date='Aug 25 2009, 08:36 AM
i tried jump starting it didnt work
My Ride: 540i
Model Year: 2017
Scott may have the best advice...Roadside Assistance. Although in his thread yesterday melimel mentioned a hammer to the starter....
Awest91
09-17-2022 11:05 PM
