Car wash ----> Car sputtering
My Ride: BMW E-60 530I
ok tried the CRC MAF sensor cleaner, same outcome. Misfire cylinder 5. I ordered a new Coilpack and soon will be replacing that.
My Ride: 05 545i
19" MRR GT1
Interior LED retrofit
I would pick up a coilpack from advanced Auto ($45) and swap it out. #5 is really easy to get to. If it doesn't work, return it.
thanks bud, i did order an OEM one and it was actually cheaper, only 37 shipped.
Do i just remove the valve cover to access it? or do i need to remove all the plastic pieces by the windshield to get access to number 5?
just curious is it normal for coilpack to fail all of a sudden? and so soon?
update: Replaced the coilpack today and she is running SUPERB
thank god there was nothing serious but I still have this one code i cant get rid of P0597..
My Ride: BMW
ok i calmed down and used my brain, i do actually have an OBD II reader. Got the following codes
P0597 - Thermostat heater control circuit open.
P0305 - Cylinder 5 Misfire
Do you think the water might have cause the heater sensor to go south?
could dirty MAF cause the Misfire?
do you think coilpacks can go bad so soon, car only has under 42K miles.
Regarding the thermostat. Maybe you knocked it loose with the high pressure hose? Isn't there some sort of sensor in the bottom front, in front of the radiator? That's the only one I can think of that can be accessible via shooting water at from the front.
you don't have to pressure wash it if you use Purple Power beforehand.
My Ride: 2004 530i, Premium and Sports Packages
I don't know if the ECU is the cause of your problem too. But it may be worth a look.
