Car is taking longer than usual to engage into Reverse
My Ride: 2005 545i Black Sapphire - Fully Loaded
Model Year: 545i 2005
I just recently notice that my car is taking a bit longer to engage into reverse. It seems like there is a 2-3 second lag or so before it engages. Has anyone had this problem?
What is the year and model of your car? How many miles on the car/transmission?
When was the last time transmission was serviced (trans fluid/filter change)?
My Ride: 2004 525i six speed w/ sport and premium package
I have had this problem on other cars and solved it pretty simply. There are additives that you can put in the transmission fluid before changing it that will help clean out the transmission. Typically you will put the car in reverse and let it idle for ten minutes or so with the wheels stopped so it doesn't move. After doing this change the fluid and cances are your problem will be solved. This process helps restore pressure in the hydraulic systems that allow your transmission to shift.
My Ride: 05 545i
Im not a big fan of addatives :thumbsdown:
My Ride: 2006 BMW 550i
Thanks I think I'll give this a try and see how it goes. Is there a particular brand/additive I should try?
My Ride: 2005 525i - mo mods...just got it
I have a 2005 525i and when it stops, i guess when the gears switch from 2 to 1, i feel a little "kick". I took the car to the dealer, they did some kind of "reset". It didnt help though. They said that i should drive a little bit for the transmission to "learn" my driving habits. I think that was complete BS, and car still didnt learn.
Other people tell me that transmission is sealed and cannot be flushed. Does this mean i cant add any additives?
Dealer suggested to replace the transmission for like 6K.
I think there must be something i could do to fix this. And yes, mine takes longer to engage into reverse too.
For the OP:
For starters I'd suggest trying the reset "technique" .. that's described in the forum - search for it. That will cause the adaptive feature of the transmission to re-learn how the car is driven. But if the problem is more severe and continues I guess you know that means a trip to a qualified BMW dealer or indy.
![Wacko](https://5series.net/forums/images/smilies/imported/wacko.gif)
Maybe it will be something simple like low fluid level - that can be checked without taking the transmission down. Find what caused that - fix it ... top off fluid ... and pray
![Blink](https://5series.net/forums/images/smilies/imported/blink.gif)
Good luck sorting it out !
