Car Stalling
Old 12-04-2006, 09:54 PM
monacobmw's Avatar
Originally Posted by zen' post='363538' date='Dec 4 2006, 03:26 PM
Did you remove the charcoal filter? If so that has an effect. And if you also change filter media the "fuel/air ratio" changes and the oxygen sensor may not be able to compensate since you don't have a 'throttle body" but have to depend on valve lift.
I removed the charcoal filter (as recommended by many here to let the car breathe).
Old 12-05-2006, 12:22 AM
arcleid's Avatar
My Ride: 2006 525i Silver Gray/Gray Dakota Leather | Steptronic | Cold Weather | Xenon | Premium Package Modifications: M Aero Kit | Carbon Fiber Kidney Grill | K&N Air Filter | Charcoal Filter Removed | Radenergie R10 Silver 20" soon | kW coilover V3 | SprintBooster soon | M5 trunk finisher Next planned mods: ?Hamann quad exhaust + Hamann quad rear diffuser + Hamann Front Lip?
Did that happen only after you removed the charcoal filter?
Old 12-05-2006, 02:43 AM
pinguhk's Avatar
My Ride: Mini Cooper
K&N filter are 100% OK in a E60.
I have had my car for over 2 years and the K&N for 18 months and it has been doing very well.
You need to put oil in the K&N filter but don`t over cook it
Old 12-05-2006, 06:46 AM
zoooming_by's Avatar
My Ride: 06 e60 3.0, Silver on Black, Premium, Sport, Sport Auto, PDC, Comfort Access, Nav, Sirius, Logic7
Originally Posted by monacobmw' post='363271' date='Dec 3 2006, 07:39 PM
Gentlemen, today, my car stalled three times while moving. Each time, the stall occurred when I was braking. My RPM meter seems to dive when the car is coming to a stop. When the car stalled, the meter dropped too suddenly.
When I put the H&N filter in the car a couple of weeks ago, the car started to make some strange RPM movements at the lower speeds.
Any relationship? Does the computer have to be reset with the H&N filter to accommodate a better flow of air?
Perhaps I got a bad tank of gasoline. I am not sure.
Any thoughts?
I would think it has to do with the idle valve control unit, either you have a leak in connecting hose or you have a faulty idle valve control unit. Let us know what you find ...
Regards,
Old 12-05-2006, 01:01 PM
zen
zen's Avatar
I don't think it would be the idle control unit because it evidently was ok before he removed the charcoal filter. removing that filter has a great effect on the engine performance. The air filter doesn't do much if anything. The air / fuel ratio is set to about 13.5 / 1. by removing the charcoal filter the oxygen sensor has to send additional fuel to compensate for the additional air flow.
PS: The oxygen sensor is not active until it warms up to it's proper temerature. During warmup the engine is running in a "closed loop". Therefore the engine is controlled with a pre programed module, which is calibrated with the charcoaql filter installed.
Old 12-05-2006, 02:09 PM
JetBlack's Avatar
My Ride: 2007 BMW 550i w/SMG - JetBlack - Dinan Software - Dinan Exhaust - Anthracite Trim - Anthracite Headliner - Sport Package
It sounds like oil may come in contact with the air-flow meter. The hot wire on the AFM is very sensitive and if oil especially gets on it then your car will stall and sometime not even start
Old 12-05-2006, 03:21 PM
terracotta's Avatar
My Ride: 2007 530i | Silver Gray/Blk | Step-Tronic | Sport/Premium Package | Logic 7 | PDC | Fold-Down Rear Seats
My buddy experienced the same problem as the OP when he put too much oil after cleaning his K&N filter at 30,000 miles. BUT, the OP bought it new, so go figure.
Old 12-05-2006, 04:35 PM
jet190rs's Avatar
how's the weather in florida?
my rpm's fluctuate (almost stall and sometimes get error msg) whenever its the 1st really cold day.
Old 12-06-2006, 08:09 AM
monacobmw's Avatar
It is colder here (Miami), but that means that it is only 65-70 degrees in the morning. I hear that we are going to get down to the mid to high 50's later this week.
Old 12-06-2006, 11:36 AM
zen
zen's Avatar
High humidity along with high air flow (without charcoal filter) can result in frost accumulation in the air intake system until warmed up.
Quick Reply: Car Stalling
