Car running temperature
A while ago I noticed that my 535d was running at a different temperature than normal.
Usually I have 4 visible white bars round the rev counter and now I have 6-7.
On a diagnostic test the glow plugs gave an error and the garage thought this may be affecting the smooth running. I have had these changed but the temp issue is still there.
My feeling is a failing thermostat as sometimes in heavy traffic the car gets up to normal temp 4 bars, but most of the time (even on a run) it stays stuck between 6-7 bars. Equally I have seen a drop in fuel economy.
Does anyone have any suggestions what may be at fault?
Thanks
Thanks
My Ride: Bmw 530d 2004
Main thermostat or EGR thermostat.
Use the hidden menu to monitor the temperatures more accurately. The engine coolant temps should stay around 88-92°C or something. When DPF regeneration is on, the temps will rise even up to 94-95°C.
Hidden menu instructions.
- Antti -
- Antti -
