Car Leaning Right - ARS SWAY BAR Issue?
So my car has leaned to the right for a while. In fact, it looks like its cambered this way front and rear wheels. I think it has to do with the ARS sway bar. On my last set of tires, the right side tires have had camber wear. When in ISTA, does it just relearn the ZERO points by itself? Or must you enter them? I have not done the ARS Sway bar test Since I've dropped the subframe.
Have a very close look at your coil springs, mine broke off a small piece at the bottom end and will also cause car to lean a bit.
ricky1329
05-16-2008 10:36 AM
