Car is dead
Old 03-26-2010, 06:20 AM
E60 545i SPORT's Avatar
My Ride: AW E46 M3 Vert
Hi guys, this morning when I went to get in the car I noticed my unlock buttons were not unlocking the car, manually opened the door... no lights came on when door was opened, tried to start the car, nothing....no cranking no lights no sounds, I was in the garage and noticed everytime I turned the key my driver corner light would blink once and go off. I'm thinking it's the battery...what you guys thinking? bought the car used back in 2007...it's a 2004 545i and I don't think the battery was replaced by previous owner.
Old 03-26-2010, 06:22 AM
SilberGrauE60's Avatar
Try jumping it. If this works, then your battery is dead, right?
Or, you could take your battery to a shop that could put it on a tester.
Old 03-26-2010, 06:32 AM
BlaSTiWi's Avatar
Also try to verify the indicator eye on the battery to see if the battery any good ... GL!
Old 03-26-2010, 06:49 AM
PraiseTheLowered's Avatar
sounds like battery
Old 03-26-2010, 08:39 AM
danzanchy's Avatar
My Ride: 545i Sport Package, Black/Grey. Got it July 09.
definitely battery... if you were having symptoms before of low battery, then this is normal. if it happened out of the blue, check your battery compartment and under the spare tire for water... but I doubt that's the case.
GL
Old 03-26-2010, 09:07 AM
No symptoms at all before this, matter of fact I drove the car 6 hours before last night and no problems whatsoever...trunk is dry, no water.
Old 03-26-2010, 09:12 AM
hmm it could be the alternator too
check the battery for the charge, if its there then its probably the other
Old 03-26-2010, 10:42 AM
How do I check the battery?
Old 03-26-2010, 10:45 AM
turboawd's Avatar
My Ride: 2006 BMW 550i
if your battery is original, i'd just go ahead and change it.
batteries usually last about 5-6 years on average, and at that point they can just suddenly die without warning.
Old 03-26-2010, 11:28 AM
bigbadbull's Avatar
My Ride: 2010 VW Passat Wagon 2.0l Tsi Grey/Grey Budapest 18" Lost to HPFP issues: 08 535i sport pkg Lost to Dreaded E61 Sun roof leaks: 07 E61 530Xi
Did it rain there last night? Not kidding this is a serious question...
If it did can you open the trunk open and look under the spare tire for water.
Quick Reply: Car is dead
