Car barely starts.. then dies on me
My Ride: 535i M / X-Drive
Model Year: 2010
Engine: N54
Ok black smoke points to a fuel issue or clogged air filter. Have you looked at your injector output? Injectors point back to the MOSFET issues the N54 has but you didn't have any of the codes so I can't definitively say it's the injectors or the DME MOSFETs causing your issues.
A smoke test is done with the car off and smoke being pumped into the intake. You look and see if smoke comes out any where and there you have a leak. You can get a cigar and tape a hose on the intake and blow smoke into it if you don't have a smoke test setup. You either have a bad leak somewhere if injector/MOFET issue. Did the engine over heat and if so how long was it over heating?
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
It's not even worth troubleshooting. You need a new engine. You never drive on an engine that's overheating. You cause more damage than just letting it sit and fixing it. These engines don't do well with over heating; none of the aluminum engines do especially overheating, cooling down rotation. If you do happen to get remotely working it will not last long.
Model Year: 2010
Engine: N54
Model Year: 05 530i
Engine: 3.0 M54
The MSD80/1 is for the N54. I don't believe I put M54 but yes you have a N54. You can try to work out your issues especially oil in the plug holes. I don't know the extent to which you drop it overheating but it is a big no no with aluminum engines.
If you have oil in the plugs then you need a valve cover gasket kit and some plugs. But as I stated above I wouldn't spend anything on the car unless it passes a compression test/leak down test.
tex_phil
85
03-26-2010 06:02 AM
John@Motorcepts
20
09-15-2009 09:46 AM
