Can you remove foglight housing on LCI E60?
My Ride: 08 528i TiAg Premium/Cold Weather Pkg, 20% Tint, Technic Harness, JL Audio 12W7, JL HD 750/1 and LOTS of lighting mods!!!!!
As the title states...anyone know how to remove the foglight housing without removing the bumper on an LCI e60(Non-Msport)?
I need to buff those foglights pretty bad....
Thanks in advance guys!
I tried to find a route around this and other then removing the front bumper you could remove the headlights and try to reach down. I had planed on doing this method but haven't had the time do it yet. For the passenger side there should be enough room, however the driver side is really tight. It was very tight just changing the bulb for the fog lights from the driver side. If you can get under the car you could try to pull the flaps down as far as possible under the bumper and you might just get enough room to remove the fog lights. Visibility will be tough though doing that method.
I'll try this...i gotta remove my headlights anyways and give them a good buffing too.
Any chance you got instructions on how to remove the front bumper just incase??
blackstarr
03-05-2015 04:54 PM
