can m sport rear bumper fit SE model?
I have 2004 530d SE. What I wanted to know is can the rear bumper be swapped round with a m sport rear bumper without any major modifications? I want to swap mine for a m sport rear bumper.
Thanks
Thanks
My Ride: BMW
Actually, for a true perfect fit, it's best to also use the 3 MTech rear brackets. The existing left and right brackets are shorter than the MTech rear. So if you mount the MTech rear, it would just hang from the top and dangle at the bottom. Also, if you don't use the MTech center bracket, the diffuser will only mount to the bumper cover and dangle at the end towards the car. Oh, and there's a plastic MTech bottom battery cover as well. I did this to mine as I wanted a true MTech fitment outside and inside.
My Ride: BMW
Looking through my old invoices, here is the extra stuff I got to make the rears true OEM. The main part numbers are the Mounts, Guide, and Battery tray cover. I bought extra mounting pins, screws, clips, etc...just incase I broke something.
51717066229 Pillars rocker and floor - Exterior trim - Rocker molding - Pin Pin Back - Sedan 2004 - 2009 16 $0.26 $4.16
51717066226 Pillars rocker and floor - Exterior trim - Rocker molding - Spacer Spacer Back - Sedan 2004 - 2009 16 $0.51 $8.16
51717066223 Pillars rocker and floor - Exterior trim - Rocker molding - Upper retainer Upper retainer Back - Sedan 2004 - 2009 16 $0.92 $14.72
51127896615 MOUNT 1 $27.81 $27.81
51127896616 MOUNT 1 $27.81 $27.81
51127897144 GUIDE 1 $21.82 $21.82
51127004445 PLUG 6 $0.26 $1.56
07146979392 BODY NUT 10 $0.17 $1.70
07129904150 Front lamps - Fog lamps - Fog lamp - Nut Nut Back - 2004-07 2004 - 2007 10 $0.17 $1.70
51717896625 Rear body and floor - Rear body - Underbody shield - Battery tray Battery tray - Sedan 2004 - 2005 1 $26.70 $26.70
Sub Total $136.14
Shipping $17.56
Total $153.70
Here are the MTECH instructions as a reference:
E60MTECHKITINSTRUCT_1__1_..pdf
socale39
09-05-2023 08:30 AM
