Can I just remove the dead Bluetooth unit without any issues?
Old Jul 19, 2022 | 11:26 PM
bmw7882's Avatar
My Ride: e60 525d M Sport
Default Can I just remove the dead Bluetooth unit without any issues?
I have a 2005 e60 and am trying to troubleshoot an issue with the iDrive (M-ASK) and CCC display
Checked the VIN and seem to have option 644 Prep. For. Mob. Ph. Bluet. Interf. and have checked the Bluetooth module in the boot and it appears to be the type without the fibre optic connectors to the MOST unit.
The bluetooth option shows up in the iDrive but wont allow me to tick the box and no bluetooth signal is noticeable from the car, making me believe the unit is dead.
My question is... can I just disconnect this module without any issues, or do I need to put some kind of connector over the end of the remaining wire in the boot.
Also, considering I might be thinking of putting in Android Auto screen to replace the CCC display, is it even worth trying to fix or replace this unit ?
thanks
Old Jul 20, 2022 | 05:43 AM
kd7iwp's Avatar
My Ride: 2009 535xi Touring 6MT, 2019 i3s
Engine: N54
I guess you save a bit of weight… do you have the SOS button? I don’t know on your car if this unit also runs that, you may get SOS errors in the instrument cluster if you aren’t already. Worth a try to unplug and see what happens.
Old Jul 20, 2022 | 08:38 AM
y0itzflip's Avatar
My Ride: broken e60 with some wheels
Engine: n54
just code it out if not being able to tick the box bothers you. what is the issue youre having?
Old Jul 20, 2022 | 09:21 AM
bmw7882's Avatar
yeah, I have the SOS button
Old Jul 20, 2022 | 09:22 AM
bmw7882's Avatar
Ultimately am trying to get the bluetooth working again. But also want to find out if this unit is whats causing the CCC to freeze up periodically
Old Jul 20, 2022 | 09:27 AM
bmw7882's Avatar
Getting this in scanning
Old Jul 20, 2022 | 09:36 AM
bmw7882's Avatar
Also wondering if this INPA info gives any insight? From what I have read it looks like loads of parts have been replaced over the years and not correctly coded to the cars VIN. Is this something that I should work on fixing first do you think?
Old Jul 20, 2022 | 10:03 AM
y0itzflip's Avatar
Engine: n54
this says a lot. the tel/mulf unit is malfunctioning. I dont think you can simply just unplug it without coding it out. but you can remove it and code it out if its not part of the most loop. but from my understanding these units are part of the most loop and you would need to keep the connection going. I had an issue with mine and I just used a loop adaptor and bypassed it. I have a carplay unit so that old tech is pointless to me anyway
Beemer junkie
Mar 8, 2022 01:52 AM
kcmckinn17
Jan 15, 2021 03:51 PM
zararory
Bluetooth & Cell Phone Forum
Aug 22, 2019 05:00 PM
ianbmwe60
Jan 2, 2018 06:34 AM
gabriel
Jun 29, 2010 05:33 AM
