Camshaft sensor 2005 545i
Old 01-20-2010, 01:54 PM
dawid_w's Avatar
My Ride: Orient blue '05 545i, Sport/Premium Pkg, 6Speed MT, Xenon, Navi, Blue2th, PDC,
Hi,
I just replaced the valve cover gasket and after I put everything back together I am getting Camshaft position sensor error P0365.
Car starts for few seconds and then it dies. I replaced the exhaust camshaft sensor (Febi), but I am still getting the same error.
Checked the wires and plugs. All looks good.
Any ideas?
Old 01-20-2010, 03:36 PM
pauliehcfr's Avatar
Originally Posted by dawid_w' post='1094394' date='Jan 20 2010, 05:54 PM
Hi,
Any ideas?
Are you sure that you changed the correct one? There should be 2 exhaust cam sensors 1 for cylinders 1-4 and 1 for cylinders 5-8
Old 01-20-2010, 05:07 PM
dawid_w's Avatar
Yes. GT1 is showing fault on cylinders 1-4 (passenger side)
Old 01-23-2010, 05:22 PM
pauliehcfr's Avatar
perhaps its an intake cam sensor?
Old 01-23-2010, 05:30 PM
pauliehcfr's Avatar
Or perhaps its the wrong one. Meaning you installed an intake sensor in place of an exhaust
Old 01-24-2010, 05:35 PM
dawid_w's Avatar
No way. They look different, so there is no way to make a mistake like this.
Old 01-24-2010, 05:36 PM
dawid_w's Avatar
What do you mean? Do you think that the problems on the intake sensor will cause errors on the exhaust cam?
Old 01-24-2010, 05:51 PM
pauliehcfr's Avatar
I was thinking that perhaps it was a faulty intake cam sensor instead of an exhaust sensor. what are you using to clear the code?
Old 01-25-2010, 08:29 PM
dawid_w's Avatar
I use GT1.
Old 01-26-2010, 10:23 AM
pauliehcfr's Avatar
Hmmm, thats a good system for diagnosing. Does that sensor have the wire harness attached or is it the sensor only with a plug connector? perhaps you pinched the wire harness when reinstalling the valve cover? without physically seeing the car, I'm shooting in the dark here. Perhaps you replaced the wrong sensor. Not to insult your capability, but the exhaust cam is the one closest to the fenders and the intake cam is the one closest to the middle of the engine. I personally have never replaced them. Does the fault description say anything other than exhaust cam sensor bank B?
Quick Reply: Camshaft sensor 2005 545i
