Cabinet Micro Filter
My Ride: E60 530i
Engine: M54
When is the right time/mileage to change those 2 micro-filter elements under the hood, right in front of the bottom of the windshield. I took mine out last week and tried to clean them. They looked very dirty !!
Originally Posted by juan2mini' date='Sep 14 2005, 05:13 PM
lcc014:
Mine came up for replacement 2 years after my manufacture date.? The service indicator showed brake fluid and mirco-filters were due - right at two years.
[snapback]170477[/snapback]
My Ride: '04 530i Mystic Blue, European Delivery, Steptronic, Prem Pkg, Cold Weather Pkg, Nav, Heads Up, Active Cruise, Rear Sunshade, Rear Side Airbags, Rear Seat Heating, Park Distance Control, Xenon, CPT9000 GSM phone, red rear reflectors, Sirius!!!!
I would not recommend cleaning these filters. They come new with an electrostatically charged layer to capture dirt/pollen and a activated carbon layer to capture smog/gases/bad odors.
Over time the electrostatic performance drops off, but the built-up dust acts as a filter itself. Also, the carbon pores become clogged. Cleaning will not solve these problems - you should replace the filter at the recommended interval. If you suffer from allergies, you should replace more frequently. In short, these filters are not "cleanable"
My Ride: 2005 545i, Orient Blue, Black Interior, Sport Package, Satellite
Is micro air filter replacement covered under the free maintence service from BMW?
My Ride: E60 530i
Engine: M54
Thanks for all the responses. I "cleaned" them by meant of turning them upside down and then shaked them hard to remove most of the dust/leaf on it.
Originally Posted by juan2mini' date='Sep 14 2005, 11:12 AM
ZinMe:
The micro-filter and the brake fluid replacement were both covered by the maintenance agreement - no cost.
[snapback]170559[/snapback]
Hi lcc014:
What I meant to convey in my prior posting was that the filter, when "cleaned" actually has worse filtration properties than when dirty, as long as it hasn't reached its useful life where it becomes clogged and the pressure drop because critical.
