CABIN FILTER REPLACEMENT/Hood Pressure Sensor
Old Dec 17, 2012 | 04:02 AM
TheBlack5's Avatar
Default CABIN FILTER REPLACEMENT/Hood Pressure Sensor
On the '07 530i, there are two Hood Pressure Sensors on the passenger side that MUST be removed in order to unlock the cabin filter housing. Thus, these Hood pressure Sensors are attached to the cabin filter housing on the passenger side. I have to remove the wire harness from the sensors before I unlocked the 13mm plastic socket.
I'm trying to unplug the wire harness, but it's just not unplugging. Do I need to pinch/turn a particular area ? Because I've been trying for days now with this simple issue. The video below explains how to change the cabin filter, but it doesn't explain how to get the hood pressure sensors to release from the wiring harness. I simply need to know how to get them unplugged, because I turned and punched the clips on the sensors but they wont come out. I know there's the correct and simple way to get them out I simply don't know it....thanks for any reply
The video is here:
Old Dec 17, 2012 | 05:47 AM
SilberGrauE60's Avatar
There should be two small clips on the plug that you push in to release. I don't recall it being much of a problem.
Old Dec 17, 2012 | 06:02 AM
TheBlack5's Avatar
yeah I've been pushing the two clips, yet it won't release. I'm going to try again. If it don't come out, I'll try to take the filters out with the sensors attached. I'll just try to just flip the cover once i loosen the 13mm socket...thanks. I'll post back...
Old Dec 17, 2012 | 06:53 AM
pcy's Avatar
pcy
On the opposite side of the 13mm plastic screw, there is a long metal clip, you need to unclip that.
Old Dec 17, 2012 | 10:24 AM
TheBlack5's Avatar
Thank you everybody. I managed to changed the cabin filters with the hood sensor pressures still on; I just flipped the cover over and changed it and everything went fine. THANK YOU!!!
Old Mar 15, 2013 | 07:09 AM
vk535i's Avatar
My Ride: 2010 535i, Sport, Nav, Platinum Gray, Blk interior
any brand recommendation for the cabin carbon air filter?
Old Mar 15, 2013 | 07:28 AM
ETNav382's Avatar
My Ride: 06 550i
Model Year: 06
I used the ones they are on amazon. Cheap, made by Mann and charcoal. Just remember to buy two.
Mann-Filter CUK 3139 Cabin Air Filter with Activated Charcoal : Amazon.com : Automotive Mann-Filter CUK 3139 Cabin Air Filter with Activated Charcoal : Amazon.com : Automotive
Old Mar 18, 2013 | 05:08 AM
vk535i's Avatar
how many miles recommendation to replace cabin filter ?
Nihilation
Jul 10, 2022 11:32 AM
Kasmo
May 7, 2019 03:30 AM
Lboy
F10 Discussion
Aug 8, 2015 08:39 PM
stormhammer
Jun 18, 2015 07:25 AM
05Mdriver
Jun 13, 2015 03:26 PM
