| pastaboi |
Feb 25, 2025 12:23 PM |
CABD ERROR while coding CCC mask2
I have tried to default code a previously fitted ccc mask-2 unit from the owner before me, but none of the options in threads I found have worked. I tried basically everything, checked that everything is set up right, sp-daten are updated and so on. The only error I end up when I try to communicate with any of the CCC ECU modules I have are nicht antworten, or in english, not responding. I came here to search for an answer, because I am in fact very troubled with the fact that nothing that helped others has helped me :(. If anyone wants to look closer into the errors or help me, please contact me. I also have teamviewer and can show you everything, or you could try to fix it remotely if anyone would be such a good soul.
Best Regards,
Pastaboa
