A/C Vents Spitting Water?
Old Jun 20, 2006 | 07:18 AM
sweetride's Avatar
My Ride: 2005 545I - Black Sapphire/black leather, sports package, nav, auto, logic 7, cold weather package, smokers package, black tinted windows.
Thumbs up
Anyone else have the a/c vents spit water at you after you press the MAX a/c button?
Old Jun 20, 2006 | 07:55 AM
Veight's Avatar
I ordered the beer spitting ones. It was an individual option and I selected Guinness.
Old Jun 20, 2006 | 08:15 AM
jet190rs's Avatar
i prefer hawaiian punch myself
seriously, compressor leak? condensation?
Old Jun 20, 2006 | 09:10 AM
my530i's Avatar
Time to buy M5 car because it does not like you
Old Jun 20, 2006 | 09:26 AM
ImolaRedM's Avatar
My guess... and this is only a guess is that there is blockage in the drain tube for the A/C. AC units will all build up water and have some means to expel the water. Generally in cars it will have a tube that will discharge under the car. If the tube gets clogged then the water will collect until it finds it's way in to the passenger compartment. Unless someone has personal experience with this I would make a quick trip to the dealer.
Old Jun 20, 2006 | 11:38 AM
UUronL's Avatar
My Ride: 2006 530i Sport Silver Gray - Black Leather - Anthracite Maple Manual Transmission Premium Audio Cold Weather Package Rear sunshade Sirius Radio Autobahnd Roadblock (3M) film kit
Either that, or perhaps you're not purging the system properly? If you shut the car off without turning the compressor off about 10 minutes beforehand, the water that has formed as condensation will remain in the system. This will eventually mildew and create a funky smell.
I suppose it is possible that the max air will force some of this deposit out upon startup which could be what you're noticing.
I purge my AC religiously after each use (AC off, blower on high, outside air for ~10 minutes), and I get some slight mist in the vapor as well as some condensation on the vents until all of it has been forced out.
Old Jun 20, 2006 | 12:35 PM
vern's Avatar
My Ride: 2001 BMW330ci, Steel Gray, Black leather, Steptronic, PP, SP, PDC, Heated seats, Xenon head lights, HK, 6 disk changer, OEM alarm, OEM clears,Iice white fog lights ,Universal trasnciver, 17 inch Michelin Pilot Sport Tires 2005 530i Titanium Gray,Black leather, Nav.,HUD,PP,CWP,SP,PDC,Xenon lights,Steptronic,Logic 7 sound system,,Fold down read seats,Power shades ON ORDER
Never purged the system on any of the BMW's I've owned.Never had a problem with condensation or the funky smell.Maybe I'm just lucky
cheers
vern
Old Jun 20, 2006 | 12:44 PM
ImolaRedM's Avatar
Had the problem in a bad way with my E34 when I was in Arizona (dry heat) but never with the E39 (wet heat) here in VA. Go figure.
Old Jun 20, 2006 | 01:28 PM
UUronL's Avatar
I'm not taking any chances.
I have had the AC smell in my previous CFC-free cars (non-BMW). That makes me think that the climate here in VA could potentially give me troubles.
Either way, I think that this condensation might be the source of the original poster's spraying vents.
Old Jul 26, 2018 | 06:35 AM
DougFarrell's Avatar
My Ride: 528i
Model Year: 2010
Default Service Bulliten on this issue.
Check out the attached and get it done before the water messes with something expensive.
File Type: pdf
