Puked coolant
Old 01-12-2016, 06:00 PM
rev run d's Avatar
My Ride: 08 535xi Wagon
Default Puked coolant
Wife came home and parked the car, and I noticed that there was a puddle of coolant on the ground, so I put my key in, and it gave me a coolant low warning.
I added about 20 oz of water to the expansion tank. What might have caused this to happen? It's the 2nd time for me to experience it in about 1000 miles. Tried searching but my search-fu wasn't up to the task.
Car is a 2008 535xi w/75k miles.
Old 01-12-2016, 06:13 PM
BostonJon's Avatar
My Ride: BMW 530xiT (E61)
easiest way to find out would probably be to pressure test the system but you might be able to find a leak if it making on obvious puddle under the car.
check the upper/lower radiator hoses for cracks, water pump seal, etc..
Old 01-13-2016, 07:50 AM
dingolfing's Avatar
My Ride: 2008 550i
Also check the upper radiator vent tube, shown as part no. 23 here: RealOEM.com - Online BMW Parts Catalog
The hose connects the coolant tank with the radiator. It is mounted on top of the radiator underneath the metal plate. If you see alot of dried coolant, the brittle plastic tube broke from the pressurized coolant. This part has been known to fail quite often.
Old 01-13-2016, 08:28 AM
twh
twh's Avatar
My Ride: 2006 BMW 530xi 6MT
Engine: N52
You got to find out where it is leaking. Get a flashlight and look around. Expansion tank, radiator, hoses, etc.
Old 01-13-2016, 12:05 PM
EddieboyS's Avatar
My Ride: 2006 550i, 6 speed manual
Inspect the expansion tank very carefully. My 550i did the same thing multiple times but continued to pass the pressure test. My indie finally found a small crack in the bottom of the tank.
Old 01-15-2016, 10:05 AM
johnbennett103's Avatar
My Ride: M5 SMG
Harbor Freight has a cheap coolant pressure kit. I used it on my e36 M3 to find a leak.
Old 01-15-2016, 05:48 PM
rev run d's Avatar
Figured it out.
11537566329 cylinder head-thermostat hose is leaking. How difficult is this to change?
Old 06-18-2017, 06:56 PM
Kbc
Kbc's Avatar
My Ride: 535xi Wagon
looks like my car has the exact same hose issue. how difficult was it to fix? thanks!
Old 06-18-2017, 07:07 PM
rev run d's Avatar
it was a water pump replacement job.
turbineguy
08-21-2015 07:05 AM
nuklep
08-20-2015 06:40 PM
Fahadddk
08-14-2015 07:04 PM
Marklublin
07-05-2015 06:47 PM
Lotus99
06-18-2015 12:36 PM
Quick Reply: Puked coolant
