buying 166 tomorrow... need advice
1st I searched, I didnt find anything...
I'm going order 166 tomorrow OEM, what should I keep in mind?
I've been reading about M6 offset, Im new to this offset thing, can anyone explain what's M6 offset really for?
and how much it will effect my car
Thanks
Thanks
well its only more flushed then the M5. it gives u a wider look. but i dont recall 166 with M6 offset, i know the 167 yes, but 166 no.im sure others will chime in.GL
Originally Posted by the chang' post='649652' date='Aug 19 2008, 03:15 AM
I'd suggest you do a little more research before making such a huge purchase. It will make the whole process easier for you that way. Garri will always be there...
I WOULD GO WITH THE REP`S IF I WAS U.... i have them and i couldnt be happyer.... less then half of what the oem would be... and there off set.. how can you go wrong... there miro wheels... listen i have the money for oem.. i just made a smart chose... G/L... if you want check out this site.. modbargains.com
Originally Posted by Ellicit' post='649957' date='Aug 19 2008, 10:59 AM
I just ordered it
ET17 for the rear once, which is the M6 OFFSET.
Originally Posted by Ellicit' post='649957' date='Aug 19 2008, 12:59 PM
I just ordered it
Yor car will look great with theses , congrats. I bought mine from Gary as well !!
