burning smell when accelerating hard
My Ride: bmw e60
my car model is bmw e60 530i ,
M54B30 engine model ,burning smell when accelerating hard ,first i check the valve cover ...and valve cover gasket no leaking oil, after i think the exhaust manifold gasket leak, and i change a new exhaust manifold gasket ,and the outside cabin filter that hole ,i also gum already ,don't give the air going into the car ...but also same....when i hard accelerating will burning smell ,sorry my english.not very good ,hope u all understand what i talking..
My Ride: 530i
Engine: M54
the following areas are very common sources of oil leaks in M54. If you're smelling burning, it's likely oil.
-valve cover gasket and ignition coil seals
-oil filter housing gasket
-CCV system and hoses; they deteriorate and allow oil vapor to enter the atmosphere
-rear main seal (mine's leaking now)
I'd check all of those for leaks. If you've never done an oil filter housing gasket, I can promise you it's leaking right now.
good luck.
good luck.
+1, I had a similar issue with a little seeping from the valve cover gasket and after car warmed up i would get a little smell. There was NO WAY I was going to put up with this oil smell ruining my BMW car smell! Ah, ended up being the valve cover gasket and after replacing all was ok.
My Ride: 535i, Premium Package, Navigation, 6-speed manual. Mods include: M5 rear bumper, custom exhaust with quad tips, M5 wheels, M5 steering wheel & shift knob, MTech front bumper and rocker panels , LED tail lights, RD Sport short throw shifter, ESS Stage 2 supercharger system with air/water intercooler
It could be your clutch slipping and burning. I just had my clutch replaced and a burning smell during acceleration was one of the symptoms.
Vman33
03-14-2022 04:43 AM
bestofthebest
03-28-2016 02:47 PM
DetailersDomain
Detailing Forum
09-22-2015 03:59 PM
