BURNING OIL SMELL FROM VENTS
Hello to all,
I own a 2004 545i 6 Speed with 67,xxx miles on the clock. Recently, I've noticed the smell of burnt oil coming through my vents ONLY when the heat is on. This happens fairly often (1-2 times per my 50 mile commute) and lasts for about 2-3 minutes each instance. Any ideas on what this could be?
Little more backround...
-I've racked the car at a friends shop and neither him or I can find a leak for the life of us (nothing from valve cover gaskets, head gaskets, accessories and no "weep leak").
-I've run searches both here and e60.net with little to no info on the subject.
-It does seem to happen more often after higher revs have been achieved, but it does also happen in low-rev/cruising conditions.
Any input on this subject would be greatly appriciated, as I would like to fix this issue before the winter sets in.
Thanks in advance,
Dan
Thanks in advance,
Dan
Hello to all,
Thanks in advance,
Dan
Thanks in advance,
Dan
Kosmos:
I have a 2006 525xi and I had the same problem. It turned out to be the valve cover bolts break in the passenger side rear of valve cover and leak oil directly onto the manifold and burn away so it is hard to find a leak. These bolts break alot if they have not been replaced. The new ones are supposed to be better that you buy now from BMW.
I found 3 valve cover bolts broken off and had to replace them. You have to buy a complete set of bolts (around $40.00). One of the bolts had the head still on and when I put a socket on it, it fell off. You may want to check all of them. The ones in rear of valve cover are hard to get to, but if you remove some of the cabin air duct work it will be a little easier.
Hope this helps.
Note.....I finally got up the courage today to do the whole valve cover gasket job. Was not fun but I got it done.
Good Luck, Hope this helps
Don
Hope this helps.
Don
My Ride: 545i sport
+1 to leaking valve cover gaskets. 67k miles is about the right amount of time when they start leaking. Definately the age thing. It (smell) will only get worse as the leak gets worse. Usually, the smell is worse while idling after cruising. The lower air flow under the hood lets the fumes linger and get pulled past the less than perfect underhood sealing.
My Ride: 525
I have the very same issue on my '04 525 with 80k miles. Not sure I want to tackle the valve cover gasket replacement, but the dealer was asking some high price last time I checked. I need to find a good local independant.
Anyone have an idea of how difficult this is and what a good independant would charge?
My Ride: 07' BMW 550i
Agree about should not be leaking, but disagree about piece of shit. I think the problem is the BMW quality control for part is piece of shit. Low end job, low wage so people don't care.
My Ride: BMW
If it's the bolts, I doubt BMW makes and designs their own bolts. I'm pretty sure that part is sourced from somewhere with low quality control unfortunately.
It would be awesome if someone can do a DIY on this. Don155, do you have the part number for the new bolts? I would like to do this as preventative maintainance since my car is nearing 60K.
Any update on a DIY or good local independant? I have a 2004 525I with the same issue....The stealer is quoting me $600 to replace the gasket...
![](https://5series.net/forums/public/style_emoticons/default/fcuk.gif)
