Bumpy ride / vibration issue with 07 550i Sport
I just purchased a used 2007 550i Sport.
The car is fantastic in every way, except for one issue. When I recieved the car it exhibted noticeable steering wheel vibration and overall vibration between 50-70 mph.
Having searched this forum and read previous threads, I went ahead and got a Hunter Road Force balance done at Firestone shop near me. Only cost me $50 which was good. The results of the machine indicated two wheels being out of balance by a little bit, and one wheel being significantly out of balance. The report also indicated a lbs rating for each wheel. One wheel was 4lbs. The other 3 wheels where between 15-18lbs which all are supposed to be within limits.
After the balancing the car now doesn't have the constant vibration between 50-70mph. However now I notice a very obvious wheel vibration which comes and goes and seems to be related to bumps in road or when going around bends at lower speed.
I have read threads that this might be related to RFTs, but i'm very surprised that RFTs have this much vibration through the suspension. It almost feels like that after there is a small bump in the road countour, rather than getting one feedback on the car to feel that change, i get a bump with continued vibration after that (almost like the car juddering after every little bump).
I increased the tire pressure on the runflats to be 3-4 PSI higher than recommendation and that made no change.
So my question - what is the next step on isolating the issue. Should I get a 4 wheel alignment done from an external shop like Firestone, or should I take it to the BMW dealer indicate to them I had a road force balance done and the car still doesn't feel right?
I can understand having a rough ride due to RFTs, but this kind of prolonged vibration with each bump seems like something else.
Thoughts?
NOTE - I also have an E46 M3 so i know what a stiff suspension feels like, and this is definately a different feeling. Best I can describe it is like a judder, but not constant.
Thoughts?
My Ride: Bmw 530d 2004
Originally Posted by omszz' post='655645' date='Aug 27 2008, 10:39 PM
bump. any thoughts?
What wheels / tires do you have?
Some wheels (a bit bended) / tires (low quality) are such shit,
they can't never be balanced
It's not the hubs nor the suspension.
Get a new set!
Get a new set!
have you considered out-of-round rims ? as in egg-shaped (xtreme).
My 04/545 (124's?) are bent, 3 out of 4, but in my case, measureable but not noticeable (at least for me).
Good Luck, mike
Good Luck, mike
I'm taking it to BMW dealer next week for another service item, and i'll have them check out the suspension as well. If that doesn't yield anything, I'll have a good tire/wheel shop look at it. I don't think the wheel is out of round, wouldn't the Hunter RoadForce have caught that?
My Ride: 08 550 Carbon Sport Almost everything factory, but no sound upgrades.
Originally Posted by Rudy' post='656237' date='Aug 28 2008, 09:42 AM
Was that available in 2007?
Don't know ... perhaps not. If not, it's even a longer shot.
carid
03-06-2015 04:58 AM
