Bulletin on Eyebrows
The "Official" Service Bulletin on Eyebrows
SI B63 17 06
Lights December 2006
Technical Service
SUBJECT
Eyebrow Lights are Inoperative after Programming
MODEL
E60 (5 Series)
E61 (5 Series Sport Wagon)
E63 (6 Series)
E64 (6 Series Convertible)
SITUATION
After programming with Progman V23.02.00 (E60-06-09-520), the eyebrow lights do not illuminate.
(Graphic here) Eyebrow lights at the top of the front headlights are inoperative.
CAUSE
Coding data in the Lamp Module (LM).
PROCEDURE
Code the complete vehicle per SI B09 05 01 (Coding, Individualization, Programming), Procedure E, using Progman V24.00.00 or higher.
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Defect Code: Refer to KSD
Labor Operation: Refer to KSD
Labor Allowance: Refer to KSD
I can add a pdf of the SIB later if anybody needs it.
SI B63 17 06
Technical Service
SUBJECT
MODEL
E60 (5 Series)
E63 (6 Series)
SITUATION
CAUSE
PROCEDURE
Thanks for the data cobradav!
My car is going for the first service in a couple of weeks.
I guess I have the CIP 19.2 but I have some problems with my AC (not the advanced one).
The manual functions sometimes work, sometimes not...?
I took my car in on 12/28 for the eyebrows not functioning after receiving CIP 23.02. Service technician loaded 24.01 and the eyebrows still did not work. They then installed 24.00 and the eyebrows are now working. The SIB shows 24.00 or higher. It appears that 24.00 fixes the problem and 24.01 does not have the fix for the eyebrows
ABC
Model Year: 2005
Engine: 545i
Yes, I agree that the thought I had was they were incompetent and did not have a clue. The service department did follow what the SIB said to load CIP 24.00 or higher. The problem is that 24.01 does not contain the fix for the eyebrows. Atleast that's what they told me and is what's noted on my service paperwork.
I originally had the 23.02 installed to fix the "slam effect" from the transmission. As we all know now that's what created the problem with the eyebrows. This 23.02 also eliminates the need to press the "accept" on the initial screen. I had to ask about this as they did not tell me. There is as service bulletin that states this is correct. It would have been great if the service department would tell you what the pro's and con's are when a upgrade is performed. Maybe if they knew themselves?
Isn't weird that the screen would ask for you to accept and then it does it on it's own?
My Ride: 07 550 silver Gray SP PKG, NAV, LOGIC 7, SAT, COLD WEATHER, STEP.
I PURCHASED MY 550 IN LATE NOV AFTER PICKING UP THE CAR NOTICED THE NAV WAS SLOW I TOOK THE CAR IN AND THEY SAID THERE WERE TWO PAGES OF SOFTWARE UPDATES. I RECEIVED THE CAR BACK SEEMED BETTER BUT THEN I READ THIS POST ABOUT THE EYEBROWS SURE ENOUGH THEY ARE OUT.
MY QUESTION IS HOW DOES A NEW CAR LEAVE THE SHOWROOM DELIVERED WITHOUT ALL THE SOFTWARE UPDATES? ALSO WHY ISN'T BMW TELLING PEOPLE ABOUT THIS PROBLEM. I WOULD NOT HAVE KNOWN IF I DIDN'T READ THIS FORUM ON A DALILY BASIS. I'M GLAD WE HAVE THIS FORUM BUT WHAT IS BMW RESPONSIBLEILITY ON THESE ISSUES.
My Ride: 11 550i Sophisto Gray/Oyster Black/Anthracite, Sprt Trns, DHP, IAS, SP, PP1, PP2, CWP, HUD, DAP, AVSP, SF RS, CA, ACC - Euro Del
Ant 550:
Please do not use all caps because it is very difficult to read. Thank you.
Originally Posted by pharding' post='373485' date='Jan 4 2007, 07:46 AM
Ant 550:
Originally Posted by Ant 550' post='373509' date='Jan 4 2007, 02:53 PM
I didn't know that it was such a problem. I didn't even realize that the caps were on to tell you the truth.
Incidentally, some online net geeks have a convention where contiguous (yes I mean contiguous) capitals MEAN SHOUTING!
ABC (oops)
