Bubbling/ Gurggling/Boiling from coolant tank, Please help !!&
Last night after about a 20 minute ride home going out 80. When I got out of the car I heard this bubbling sound, almost like hot water in a pot. When I opened the hood, it appeared to be coming from the coolant tank. Obviously I didn’t dare open then. I have never noticed that sound before. I don’t notice anything leaking or any odd smells. Please help
Did you go to the dealer recently? My dealer over-filled my coolant bigtime. It's probably just overfilled.
After the engine is cold, check the level, if it is really high then that's the problem
Run the engine with the cap off. let it get warm. if you have bubbles it may mean a leaking Head gasket, especially if there is any white smoke comming out of the tail pipe when you start the engine after it sets a while.
Nope no messages on the idrive. I did however just try the temp gauge tirck and went for a drive. I was pretty stable at 105 degrees. However oddly enough I randomly just got a low oil light. Just checked my oil and it wasnt low. I am not sure if I threw something off wack by going through the menus to get the temp guage trick to work
Did you do anything to your cooling system recently? Maybe air in the system? There's an automatic purge program on the 545, search and you'll find a pdf from TIS on this forum.
Vman33
03-14-2022 04:43 AM
bestofthebest
03-28-2016 02:47 PM
