BSD Issue - Possible Water pump?
Hi all,
I recently started having an issue with the BSD line and wanted to see your thoughts. The car is a 2010 E60 535i. Couple of days ago I went to check my oil level in i-drive and noticed that it said that the oil level reading is inactive. So I started looking into the issue. Went through the BSD troubleshooting by unplugging each BSD component one by one - IBS, Alternator, Oil level sensor and waterpump. When I unplugged the waterpump, cleared the codes, the code did not appear again. I plugged the waterpump back in and everything was working normal. The oil level was active again and the waterpump did not run constantly. So I figured it must've been a bad connection at the waterpump. A day later the issue came back. Is it possible that the waterpump electronics are on their way out? Like I said, when I disconnected the waterpump and plugged it back in it was all good. I'll go under again today to clean the plug really good and see if that helps. Thank you. |
Possible. Good debugging....divide and conquer.
So, your vehicle did not throw any relevant DTCs?
Originally Posted by donpb
(Post 1622803)
| All times are GMT -8. The time now is 02:22 AM. |
