brakes
Hello..I took my 04 525 in for a brake inspection last week because I could hear the brakes sweaking...On the work order it says that they changed the pads.. I still hear a slight sweak when braking..is this normal after new pads? Will it go away with time?
Also when I change gear (r to d) in a still position I hear a creaking noise from the back side of the car..Any ideas? Thanks in advance for all help
My Ride: Alpine White 2007 550i
My Ride: G30 M550i
Model Year: 2018
Before you worry about all that stuff posted in the thread on bimmerfest, take a look at the posts here that reference the brake wear sensor issue. There are a bunch of threads about them but here are a few of the main ones:
http://forums.e60.net/index.php?s=&sho...st&p=341921
http://forums.e60.net/index.php?s=&sho...st&p=351225
Well the bedding of brakes doesn't cost anything or require a service appt, so I should think one would start there as a first measure since it needs to be done to those new pads anyway. If that doesn't fix it then perhaps it is time to start changing sensors.
My Ride: G30 M550i
Model Year: 2018
I have change the brake pad to EBC green stuff which I thing are very good no mice or dust now.
bestofthebest
Mar 28, 2016 02:47 PM
