brake sound
whenevr i brake, to slow down to standstill, i hear very high pitch sound. Its like metal rubbing.
to me, it's like one of the brake pad is rubbing on rotor (instead of biting), while the other bites hard when braking. I say this is because it's very loud (even with windows up) when car braked til zero speed, especially.
some friends say BMW uses lousy brake material, he suggest I change to carbon brakes to solve the problem, and also it produces less dust and more brake power than stock.
I hesistate to change, as my car is only 1 yr old, and hence brake pads are still new, maybe it has another 30,000km to go...
any advise?
any advise?
My Ride: '08 530i Luxury LCI
any advise?
any advise?
sound still exisit, though softer alittle. but after a couple of days of driving, sound comes back.
some friends say maybe some stone or hard particle got stuck in between pads and rotor...
![Help](https://5series.net/forums/images/smilies/imported/help.gif)
Why not take the car to a trusted garage to examine further?
My Ride: 530d M Sport Lci
any advise?
any advise?
I am having the exact same problem had the car for 3 weeks and i first heard it a couple of days ago, I did some hard breaking and breaking while driving, and i thought it stopped, but it did it again today, during the day but not in the evening???
need to see what happens in the morning, did you ever find out what was causing yours?
There is nothing to worry about. This is a very common problem for us E60ers. OEM brake pads tend to squeal a lot even after 3month of use. They make noise when stopping and cause a lot of dust.
What you can do is change to ceramic brakes such as : EBC Green Stuff Brake Pads or axxis brake pads. They dont make any noise and cause much less dust on your rims
NB: also try to make sure that the sensor is not warn out. Sometimes the sensor gets damaged when the pads are at their almost finished thus causing that noise.
Me dealer also told me this is common for the OEM brakes when (fairly) new. Something to do with the pads and rotor linings/coating, which will eventually dissipate after a few thousand miles. :thumbsdown:
It was said to reduce brake dust and make better braking too.
not going to spend too much finding out the actual cause, but if anyone has some idea of the cause, it sure helps to understand better on our E60.
