Brake rotors hex screw sizes needed
My Ride: Sapphire Black 07 530i non-sport
7000k Angel Eyes
6000k HID Xenon adaptive turn Head lamps and Fogs, Clear LED Turn Signals front/back and side markers. Clear bright license plate lamp. Full interior lighting upgrade.
Coding: daytime angel eyes, auto windows up, and digital speedometer. (Thanks to John at Motorcepts.com)
OEM Tinted LCI Tail lights (Thanks to David at http://www.luxmotorwerks.com
Oem Mtec rear bumper with diffuser and M5trunk finisher
Debadged! The best paint work! (Thanks to Desimone BMW)
20x8.5 +18 20x10 +25 Concept One RS-8 Black Machined Chrome Lip
V6.1 cables (Thanks to Bruce Miranda)
Nitto Invo tires 285x30 R20 - 245x35 R20
Discounttire.com
Vac Motorsports ecu chip upgrade, and fender roll
http://vacmotorsports.com/
wish list:
Rieger Front bumper
Hamann side skirts
Custom quad exhaust
Rpi Ram air intake scoop
M5 SMG shift knob
KW Variant 3 suspension
Brembo Big Brake kit
LCI Heads
Tints
BMW M5
I'm about to work on the brakes and rotors. I don't want to get a whole set of hex sockets but can't remember what sizes I need for my 2007 530i
Anybody know the size required? And any abnormal tool that I need in order to change the brakes and rotors?
Tia
Tia
My Ride: 09 E92 M3, 07 550i
Please it was a 6 or 7 mm alley if I remember correctly
7000k Angel Eyes
Discounttire.com
wish list:
Rieger Front bumper
Hamann side skirts
Custom quad exhaust
M5 SMG shift knob
LCI Heads
Tints
BMW M5
A 6 hex fits perfectly, and the same kind you use in the engine bay screws also work.
Problem was, mine was rusted in. Had to drill them out anyway.
Maybe post a DIY on how I did it later.
My Ride: 07 525i Alpine White
I believe it is a 7mm hex for removing the 2 screws pointing to the inside of the car
something like this:
Sears.com
got mine at NAPA for like 3-4 bucks
This link has the PDFs for the front & rear breaks from BMW mechanic guides.
If you want a more detailed one I will try to find the one I used when I did mine.
DIY for Brake Pad Change? - BMW M5 Forum and M6 Forums
as far as the actual rotor it is held on by a common size and a multi-tool one should have the size. Don't remember it off the top of my head. Doesn't require a ton of torque so the multi-tool worked fine for me.
Sears.com
A 7mm hex tool is required for the caliper guide pins. This is not a size that is included in most sets. You'll want a standard length, 3/8" drive socket. The NAPA Carlyle brand is good (Taiwan), but Sears has gone to China. There are many other tool brands to choose from.
I used a impact hammer to remove mine. More than likely if you try by hand you will strip the head. I think the impact hammer cost about $12.00 at just about any parts store.
