Brake Recall
My Ride: 2005 545i
Cold Weather Package
Navigation and Logic7 Package
Sport Suspension Package
Hey guys,
So i got my car back from the stealership and the service guy started to tell my how i am leaking oil from my valve cover and my vaccum pump is bad and that i would cost over $2000 to fix it... he said it would be $1188.98 for the Valve covers and $779.85 for Vaccum pump... does that sound right to anyone??? any advise? i need some serious help....
My Ride: 2005 545i
i just looked up the parts need to do the up an is under $600.00 to do it.. so i dont see how they could get up too $2000.00
My Ride: '04 545i, sport pkg, premium sound, sprint booster,
I could understand that if the car is still covered by BMW. If it's not however, as long at the shop has certified BMW techs it shouldn't be a problem. I had no problems with the shop I've used and they have done some major work on my car. Going to the dealership your just another customer, a number. My indy shop knows me by my first name.
My Ride: 95 M3 CAI, chipped, pulleys, Xbrace, doesn't give headaches every time I start up!
04 545i all the goodies INCLUDING HEADACHES!
I had mine done by a BMW independent shop that also replaced my timing cover gaskets, oil pressure O-ring and plugs for $1400.00 total. Did a good job too. Dealer quoted $2300. Feel around the back of the valve covers with your fingers when the engine is cold to get an idea on how bad the leak is. It's easiest if you pull off the plastic covers. it just may be seeping slightly and getting things dirty. Mine were leaking pretty bad and my fingers were wet with oil when I checked. I was also leaking at the alternator mounting seal that the dealer missed when they inspected.
My Ride: 2005 545i Black. Premium, Sport, Winter packages. PDC.
bestofthebest
03-28-2016 02:47 PM
